1 - 11 of 11 Posts
So i recently bought a 2006 530i with a manual transmission.. Runs great had no issues the first day.. On my way home from work I was making a U turn in front of my house and I accidentally stalled in 1st. (Still getting used to the clutch) So I turned my key back like if I was turning the car off and I tried to fire it up again but all I heard was a click in the driver side engine bay/ firewall area.. First thing I thought was my battery might have died. So I had a buddy come over to jump start the car. We tried jumping it and the same thing happened. Just a quiet click.
Well after sweating a thousand bullets I figured I could push start it since my car was on a slope. I put it in reverse popped the clutch and the car turned on. I figured I would drive it for a while on the freeway in case the battery needed to be charged. The car drove like a champ with no problems but when I turned it off and tried turning it back on nothing happened.
There are no warning lights on the dash and the car runs great when I push start it. I feel like the starter maybe got stuck when I stalled it. Any help would be greatly appreciated! Thanks my bimmer friends.!
My engine cuts out and i hear the same exact click from under the glove box. I wonder if they're related somehow.
Mine only happens when its cold in the morning. I replaced the fuel pump relay without any luck. Hope you fix yours, i think we might have the same problem and mine is on its way out.
2004 530i
Bad starter motor
Discussion Starter #5
2004 530i
I hear the fuel pump turn on when I turn the key.. Seems like that might not be my problem. But then again. Im not 100% sure. :(
Im new to working on bmw's.. But is the starter and the starter motor the same thing.? Or in the same location.? Im at work now so I wasn't able to further search this.. Thanks for the help bud.
Yes
It sounds like a bad starter to me, too. It is a bear of a job on the N52 engine that requires the removal of the intake manifold.
Discussion Starter #8
Ok cool. Thanks alot. I've been searching around and yes it indeed sounds like its the starter. I'm heading to my mechanic in a few to drop off my car. Its such a bummer considering I just bought the car 2 days ago.. Anyway. Anything in specific that you have to do after installing a new starter.?
I was told you have to dial/ program in a battery once you replace it. Would replacing a starter need a process done after being installed?. Thanks in advance!
Discussion Starter #9
No, believe it or not you can just swap out the starter and not have to code anything.
Did you buy the car from a dealer? Is there any kind of warranty (30-day/3,000 mile) on the car's major components?
Discussion Starter #11
Thanks a lot bud. I bought the car off craigslist.. 2nd owner - 152,xxx miles always garage kept for $6500.. The car is beautiful. I did feel the starter a little slugish when I turned it on. So most likely it was already on the way out. I had my mechanic replace the starter for $200. Which I thought was super cheap considering that the manifold had to be removed. Now it turns on like a charm. Thanks.!
1 - 11 of 11 Posts
