Well this morning I turned on the 540, put it in reverse, went about a foot and car died. I am now getting Engine failsafe prog and Trans failsafe prog and the temp gauge moves into the red after a few seconds. Everything seems to be working but car will not crank or do anything, as if the starter was removed. I have ran diagnostics and here is the following codes that came back for IKE:
246 Data connection to drive and running-gear-control modules (CAN Bus)
247 Data connection to drive and running-gear-control modules (CAN Bus)
248 Data connection to drive and running-gear-control modules (CAN Bus)
251 Data connection to drive and running-gear-control modules (CAN Bus)
Anyone ever had this happen before?
I did a search and found only one person that had a faulty MAF, but their situation was a little different.
I am trying to save a little bit of $$ by fixing it on the spot and not having it towed.
Also, diagnostic is unable to communicate with DME.
Any ideas would be helpful.
