I'm in the middle of replacing the upper timing cover and valve cover gaskets and have run into a problem with the passenger valve cover.
I've successfully removed the cover, replaced the gasket, and partially reinstalled the cover (including getting it safely over the eccentric shaft sensor). The cover is about 1/4 inches above where it needs to be. I suspect the new spark plug dome tubes are refusing to budge, but other than hammering the valve cover, I'm out of options.
So far I've tried to lightly hammer the cover with a rubber mallet. I've also removed and realigned the valve cover 4 times now, removed the three red plastic guides at the bottom, and put silicone lube on the tube gaskets. I've put all my weight leaning into the cover and it won't budge.
Any suggestions? Thank you.
