550i No crank No start (video inside) SOLVED
1 reading
1.3K views 19 replies 5 participants last post by  Ssilver356
#1 · (Edited)
Hello everyone,
My 550i won't start, or it starts randomly after numerous tries.
I have the impression that I can hear the starter clicking and retracting.
Test :
  • Other Battery --> no improvement
  • IBS disconnected --> no improvement
  • IVM board cleaning --> no improvement
I saw that it could be the CAS, a ground strap, or the starter itself.
What is your opinion?
Thank you for your help
#7 ·
My bad, I forgot you said it will fire up. yes it is, removing the motor mounts (the one off the block and one on the subframe) might help with space under there. hoisting/jacking the engine up might help too. I feel as tho the subframe will be a pita to work around. I pulled the starter off my dead TU when I pulled the motor and did not envy those trying to remove that thing still in the engine bay!
