Morning!
First post on here so please go easy on me! I got the 5DB3 error on my E91, Also, usual driving stability, DBC failure and FTM system error...Bit of searching around and suspected it was the wheel speed sensor, changed this, cleared the fault with my cheap reader and the fault remains!
Took the new sensor out and it was slightly damaged at the end so I suspected the reluctor ring had caught it whilst on my test drive. So, new reluctor ring fitted. Put the same "new but slightly damaged" sensor back in, cleared the code and a test drive threw up the same error.
Ordered a new sensor from Amazon, fitted, cleared fault. Test drove this morning and still the error is present!
Where do I go from here please?
1. Is it the sensors I am buying (£10-£15)?
2. Is my cheap reader not capable of clearing the code properly?
3. Does the sensor need certain mileage on it for it to start working, I am only going 1/4 mile on the test drive, is that enough?
4. Could it be something else? I have seen the bearing suggested in other posts?
Appreciate any help!
