1 - 6 of 6 Posts
Hi all, my auxiliary water pump isn***8217;t working. It works with a direct 12 volt feed, the supply from the car is 4 volts. Any ideas what the fault could be or does anyone have a wiring diagram so I can trace the supply?
I have already replaced the heater control valve.
Thanks in advance
Super Moderator
Hi all, my auxiliary water pump isn't working. It works with a direct 12 volt feed, the supply from the car is 4 volts. Any ideas what the fault could be or does anyone have a wiring diagram so I can trace the supply?
Thanks in advance
4 volts sounds very strange? What is your battery voltage, & have you had problems with the engine running or cranking?
Discussion Starter #3
Battery voltage normal at 12.5v no engine cranking or running issues.
Super Moderator
The wiring diagram shows the the wiring back to the temp controls, but it does flow the the IVM module. There could possibly be a blown fuse blown on the IVM, which is located under the passenger side cabin filter. Have you tried jumping it straight to 12 volts to make sure it works?
Discussion Starter #5
The aux pump does work with a direct 12v supply.
I had a look in the box under the passenger side cabin filter to check plug connections but didn’t see any fuses. I’ll have another look thanks. I would have though I would gay any voltage when testing if a blown fuse but definitely with a check. Thanks.
I have sourced a wiring diagram so will let you know how I get on.
Super Moderator
Search IVM module & you will know what to look for. It is slid in the side of the box, & can be hard to remove at times. Once removed you can see the fuses in the module. You also have a fuse panel in the glove box hidden in the rear, & one in the trunk. The pumps do go out at times, there might be some help in the DIY section at the Sticky at the top.
1 - 6 of 6 Posts
