1 - 2 of 2 Posts
Hello everone,
I would like to tackle the front strut replacement today. Unfortunately I am unable to find the torque specs for my 05 645ci.
Bolt torque specs I need to figure out are:
1. top strut nuts torque spec (part#2)
https://parts.bmwofsouthatlanta.com...2005&ukey_category=17340&ukey_trimLevel=11832
2. bolt pinch area to clamp down the shock to the knuckle
3. bolt that holds the Y cable bracket on to the knuckle
*2 & 3 (parts 3,4,&9)might be the exact same bolt/nut combo torque spec based on the schematic I am looking at.
4. front and rear lower control arm bolt/nut incase I have to remove them from the subframe
5. ball joint nut front and rear lower control arm incase I have to remove them from the knuckle to get the strut out
6. sway bar links incase I have to remove them to get the strut out
7. swaybar link bracket (part#9) for each swaybar link. I saw a video for the 5 series, some bracket needs to be removed to get the strut out.
ANY info would be greatly appreciated.
-Frank
1 - 2 of 2 Posts
