241 - 260 of 976 Posts
I maybe found a company who can code it for me i ask them what they charge for it. Because after reading this the 270 programmer cost me 130 euro maybe it is cheaper to ask the company what they charge for it.
I thought it was only coding and adding vo and so that is what i can do.
Hello!
There should be also the long vin and the short vin inside, not only the short one. On the same place like 6WA.
CU Oliver
Hello!
Hmmm, I desoldered the eeprom grom at least 3 6WB and for sure, there was also a long vin inside.
Cau Oliver
I have one more question do i need to change cable or connectors when i plug in the 6wb or can i use the old one without any modification?. Lets say is it plug and play?
And i found a shop near my house who can code it for me or he is going to try it atleast :p
Finally today i have my 6wb coded and working but now i have lost some features. I don't see the traffic sign display any more not even in my HUD. The second issue is i don't see the car dynamic efficient working the thing in blue in the right below corner that said that it is charging your battery.
The coded is coded by someone els because this was a used 6wb kombi instrument. No soldering for so far i know because i left the car there for almost 6 hours.
Discussion starter · #255 ·
Discussion starter · #257 ·
Hi,
Could anyone tell me if the 6WB is a generic cluster and if it would fit a 420i (2014) Xdrive Gran Coupe (F36) M Sport?
Cheers.
No. 6WB Fits only Fxx 5, 6, and 7-Series cars.
nav directions is not showing on me 6wb
Hi guys..
I retrofit a 6wb cluster on my 2013 bmw 740Li
Everything whent well...
But with one issue....
That is: my nav direction arrows is not showing anymore on the 6wb cluster...
The one who coded the cluster for me... told me that you need a cable that connects your 6wb cluster to the back of the NBT... then you will get the directions showing up on the cluster...
Is that true??? Do I need a cable that connects the 6wb cluster to the NBT??
Hi,
For trafic sign You need to code FDL Your's kombi - search to activate this parameter.
Everything whent well...*
