421 - 440 of 976 Posts
I dont have the NBT, this Menu i Never see in my car. Maybe i have not Code all possibilities.
I have 520d from 12/2010, retrofited Nav Prof with new ZGW, HUD, 6wb an i have only this thinks updated with newer Software.
Markus
Remplace 6WA by 6WB questions
Hello Everyone,
Here I have some questions about the 6WB
My 2010 F01 has the following options: 6WA, Head Up Display, Lane Assist, Speed Display indication.
My questions are as follows, if I install the 6WB what are the problems ?
My Head up display will show it the same informations ?
thank you for return
Xavier :)
Discussion starter · #429 ·
Hello.
Does anyone know where i can find a virgin BIN for my 6WB?
Are there different versions?
Do i need to desolder to revirgin it? (it has lower KM than the car)
PM sent.
You need to Desolder EEPROM from motherboard in order to write new Data to it.
Discussion starter · #431 ·
Discussion starter · #434 ·
Discussion starter · #436 ·
Thank you.
Do you know if it possible to just replace the eeproms, i mean to take the eeprom from my basic cluster and put it in the 6WB.
You can replace with a Blank virgin EEPROM, but not the one from your Basic Kombi.
Discussion starter · #438 ·
Do you mean by (Blank) a brand new one ?
Do you know the EEPROM ID/number ? Is it available in the market ?
You need to get EEPROM details off the EEPROM in your 6WB. You can normally buy a virgin EEPROM, but nobody sells just one chip, so there will likely be a package quantity / order minimum.
