461 - 480 of 976 Posts
Discussion starter · #469 ·
does anyone know which option is to rise sport displays in sport mode?
I have 640d with 320HP as standard, done chip and rise power to 410HP
any possibility to change torque and hp??
No. Ranges are baked into firmware, and are not codeable.
thank you very much!!!!
I finally have solved the tamper dot problem!!!!!!!!
thank all of you very much!!!!:rofl:
but There is another problem....:cry:
please see pictures!!
I am korean!!!!
but i can not see korean in my 6wb......
How can I solve this problem?
please some one help me and Please explain to me in details.
I believe that you can solve this problem !!!!!!!:thumbup:
thanks!
looks like your CIC is flashed with FA from EU
you have to get a valid korean FA and flash CIC with korean language inside pzdata
hmm, but i never seen korean ISTA/P, good luck :)
@shawnsheridan
you are not right, i changed the torque and hp with only coding my CIC or my KOMBI, without flashing CIC
i mean it was KOMBI, just try it
Discussion starter · #472 ·
...@shawnsheridan
What is FDL Code(s) to change the Sport Display Ranges?
And we are talking about the Range, not the Units of Measure which can be easily changed by FDL Codes DREHMOMENT and LEISTUNG.
the question was:
so its possible to change it,
but i dont know how to change the perfect torque for a chiped engine, there you are right shawn
my car has 400torque i changed it to 320 for testing, it was changed at CIC
Discussion starter · #474 ·
the question was:
The OP actually asked:
He is wanting to increase the range of the Sport Displays.
My response was:
You stated I was wrong in my assertion. If what you say is true, then what is the FDL Code(s) to change the Range?
I would try to code the next stronger engine, it will maybe show then right range, i have there no exp about chipped cars
I just want to say, that i have changed the max HP at CIC, dunno about the range is changed or not
I know somebody with chipped engine at F10, i will try it there
no risk no fun, you know ***128515;
Discussion starter · #476 ·
Ok, so what specifically is it that you coded to "change the max HP at CIC"?
Discussion starter · #478 ·
i have coded FA from F10 (my car is F25) to my DKOMBI, and the max HP was changed at CIC
i havent compare the change about FDL, just playing at the time with red dot at KOMBI
maybe in somedays i will get some time, and check it
Well, if you ever figure it out, please share, as I have never seen nor heard of anyone changing any parameter in Kombi and having Sport Displays in CIC Change range. To get the Range to change for MPPK, DME must be flashed (no coding).
Discussion starter · #480 ·
Can anyone send me a bin file of a 6WB wiht hud F 10 (160D0WQ EEProm) ?
I have a 6WB with a EEprom that I can't read , so I need to put in a new one.
PM sent.
