501 - 520 of 976 Posts
Hello guys, I am retrofiting an used 6WB to my 2010 F07, so I have some questions
I have a red dot on cluster I have read eeproms 35160D0WT and 95320WT, but I have't found full vin and milage lines, on 35160D0WT there is two places with short VIN and on 95320WT there is one place, still can't find the full VIN any ideos on which line is it? Also about the milage which lines is it writen in?
Also another question about coding, I have wrote 6WB code into FA changed manufacture date into 0313 saved it and coded into car everything looks fine but, I still have KOMBI line instead of DKOMBI, any ideas? Maybe my ZGW (gateway module) is too old?
Cheers!
Cheers!
Everything works ok after, virgin cluster was done!
Hello everyone, I wanted to share with you my misadventures in having mounted a 6WB on my vehicle.
I own a 2010 F01 but its year of manufacture is September 2009 she has all the options, except for night vision.
I replaced the 6WA by a 6WB latter had been reset by the seller.
We have modified the code FA 0909 by 1212 and then E - SYS refuses this year the only accepted is 0912.
By installing it on my vehicle was immediately recognized and put the right configuration to know diesel version and all the driving AIDS, only two items appeared in defects (inoperative emergency call, and the CBS have updated).
Similarly, when we wanted to Flash the DKOMBI meter with E - Sys error appears on the LLR21 that corresponds to the ACC+.
My specialist told me to replace some modules such as ZGW 01 by a 02 CIM and another case what to think of you.
I am surprised because I had asked the question to Bimmertech and Bimmer24 in Germany with my VIN and the response is No problem ist OK.
Have you done a wrong procedure or is there a special procedure.
Have you ever met this type of problem on a 2009 F01? Thanks for your answers and your help.
Best regards
Xavier
Yes, you can code it with E-Sys. If it is new and not used, you can do just as I wrote in my original post, which is add 6WB to the VO, change VO Production date to 1211, and VO Code DKombi and HU_CIC.
thats it? just plug/play and FA code and code Dkombi and HU_CIC? So i can buy car 2012 and cables will be the same? what if the 6wb will be used from another car?
