941 - 960 of 976 Posts
I went back and tested this, and the FDL Code is MOTORLEISTUNG_ENABLE = aktiv to enable it. The meter scale units can be changed from kW to HP from the iDrive Settings menu:
View attachment 411623 View attachment 411624
Even when I changed it to HP, it still showed a digital readout of 80, unlike this picture below that is showing 480:
In all cases, it does not appear to be working because it is always maxed out with little or zero RPM's.
The code for this one is DIGITAL_TACHO_ENABLE:
View attachment 411620 View attachment 411619 View attachment 411622
It can be set for either mph or kmh and is independent of the main speedometer's unit of measure as shown in the picture with the main speedometer in mph, and the digital speed in kmh.
It is a nice addition to the Comfort / Comfort+ display, but redundant on the Sport / Sport+ display.
Hi Shawn!
Which FDL Code need to change for appling speed in center bottom of 6WB? like here
As i understand DIGITAL_TACHO_ENABLEs only in speed gauge.
So except D_KOMBI, shall i code FDL something in HU_NBT to enable digital speed by pressing "BC" button on the
turn signal lever?
Discussion starter · #942 ·
Hi Shawn!
turn signal lever?
In DKOMBIM it should be BC_DIGITAL_V = aktiv,
  • Like
Reactions: pekod_065
Hi, Shawn!
Im trying to replace deffective 6WB on F07 LCI. I virginize it with VVDI xprog. But during coding it gives me an error "WDBI_CPS returned with negative response" I read your other posts in other tread, where you suggest to properly revirginize it. I did that, but same error. I thought that maybe the file in eeprom was corrupted and grab the dunp from another cluster 160DOWQ eeprom (with matching part number of cause). Wright it, virginize it, and try to code again, but same error. Could you please give me the advice what else could I try. Thanks in advance
Hi everyone. I just got fitted 6BW to my 2014 F31.
So everything works good, except one thing. When I start route in my navigation, and dashboard shows directions arrows a strange glitch appears. And won't go away until I stop my navigation route.
Any idea how to solve that?
If you have HUD, try turning it on.
Hi guys, just registered in order to get some help here...
So
I've bought a used 6wa for my diesel F30.
As I had bad luck with my chinese programmer I had to ask someone to virginize the cluster.
The cluster showed 0km and an empty VIN.
I did the install with the new MOST Y cable and coded it to the car.
As it still showed 0km (but NO RED DOT) I decided to flash the kombi to see if that would sync the mileage.
Coding and flashing went well, I also coded the other modules of the car with 6wa on the FA. However the mileage still counted from 0 (right now 17km) and NO RED DOT.
So I decided to check with ISTA and ALL MODULES thins this is the correct mileage. DME thinks the car has 17km and the gearbox think that the car has 17km.
I havent touched those modules besides coding with an FA with 6WA. I don't even think I would be able to change the mileage on that modules with Esys even if I wanted to.
If I install and code the old cluster back I get the 250xxxkm also without the red dot. Reading with ISTA shows 205xxxkm on the other modules then.
Reinstalling the 6WA and everything goes back to 17km.
So how can I get my real mileage back again? The service indicator seem confused, the CIC knows that I have an oil change in 1300km and that's accurate but it also thinks I should have had an inspection 160.000km ago
If I drive some more will it eventually sync the the CAS and DME?
I just want my mileage back.
Thanks.
ISTA thinks it has 17km
No errors in all modules
DME thinks it has 17kms
Gearbox (I think?) also agress with 17kms
Cluster shows my VIN so it has been coded correctly
CIC knows about the oil change
But CIC is confused about old service history.
Hi all,
Can someone please send me virgin files for f06 6wb cluster with hud.
Many thanks in advance.
EDIT: not needed, easy enough to reset mileage using R270 and FF out the 2 short VINs in the 160DOWQ. Still had red dot after coding but it went away after letting the car go to sleep.
