141 - 160 of 976 Posts
Discussion starter · #141 ·
I didn't flash mine. I just injected CAFD and VO Coded it, and left it like that. I will flash soon with 54.x though.
Did you try flashing it with the check the box that says "HW-IDs from SVTactual"?
Did anyone try to retrofit 6WB in F10 M5? we try to do one but the M button and all sport mode will not work after the retrofit.
I guess the 6WB can't install on M car? because the M car does not have those mode selection (comfort, sports...ect, only has those mode change individually on suspension, steering wheel, edc..etc)
Can someone please confirm?
At moment, it looks like that cluster think it is in a normal F10 car rather than M car, so I guess maybe the 6WB cluster is not for M car at all?
Hello!
I never tried it with my M5 and I'm sure that it would not work. This SA is not specified for a M5 and should cause more problems than the new look could bring for me.
It's hard enough to retrofit a 6WB into a normal F10/F11/F07. :)
CU Oliver
Discussion starter · #146 ·
On ///M car, FDS signal comes from DME, and not ICM, and Gear position comes from DKG instead of EGS, so Gear Display and FDS Display's would not work. And without ///M Kombi, the M1 and M2 buttons on steering wheel would not work.
Discussion starter · #151 ·
What is HU_XXX => KOMBI_CIC set for?
Discussion starter · #154 ·
That is correct for 6WB. I don't know what is going on then.
In latest CAFD exists possibility to vary the tachometer scale with 300 or 330 kph, but it doesn't work.
I think that will be activated in the future or never, I'll try to see if there is to change other voices.
