Hi,
I recently got an air bag error on my 745i, so I scanned it with INPA and got error code 9763 SSFA. I can't seem to find an answer for this, as some say that its the passenger occupancy pad, others say its an open circuit. Anyone familiar with what this code is, and what should be done to fix it?
HAVE YOU TRIED USING THE SEARCH FEATURE ???
http://www.bimmerfest.com/forums/search.php?searchid=30186420
says "sorry - no matches. Please try some different terms." when i click that link. Sorry man
link works fine for me !!!
thanks a lotBELEGUNGSERKENNEUNG_FA
sbe1
TO:
keine_sbe
FOR SSBF
BELEGUNGSERKENNEUNG_BF
oc3
To:
keine_sbe
clicked it again, still doesn't work. I came across a thread that suggested switching off the occupancy sensor using NCS expert, but my question is would the airbags still deploy in an accident if I do that, or do I have to get the bypass adapter installed? The code is
thanks a lot
Yes, they will deploy. Switching it of just disables selective deployment. This means if you crash rather than only deploying if there is actually a passenger there it will now assume there is one and deploy.
The bypass adapter in this way does the same thing, it removes selective deployment.
I saw that Fatboy 613 was not able to find the varaiable "BELEGUNGSERKENNEUNG_FA" in the SSFA module. I have a 2004 745Li and could not find that variable in the SSFA module either, however I did find a variable called "ERKENNE_SBE1_MATTE_FA" which translates to "Recognize SBE1 Mat FA." The value in my car for this variable was "aktiv."
I coded the value to "nicht_aktiv" in the "ERKENNE_SBE1_MATTE_FA" variable and then cleared the error codes, the light went out and warning disappeared.
So far, no airbag light or drivers restraint warnings popping up but time will tell, it has been only a couple of days. In the past when I cleared the error code (without recoding SSFA) in a week or so the error would be back. I will be curious to see if this coding change fixed the error from reoccurring.
From what I can tell, SSFA module is driver's side, SSFB is passenger side.
Also from what I read online, this coding change only makes the occupancy sensor mat in the seat inactive, which causes the car to assume the seat is always occupied, thus airbags will always deploy in a crash. For drivers side this seems like a non-issue, but if you change coding in passenger side module, the passenger airbag would go off all the time in the event of a crash, even with a small child in the seat, or with nobody in the seat at all. Code at your own risk!
Glad you got it working. Which bypass module did you need? Was it the driver's seat you installed it on?
I read up & the info I found said that my 2004 745Li could use either a 2-wire or 4-wire bypass module, sounds like your car is a 2004 E65 also, so I was curious what it used as it is probably the same as mine would need.
Did you have to take the seat out of the car, or just move it up and forward all the way?
Thanks,
Mike
