//////Solved!//////
Read post #15
2007 750i 84k
***I posted this in bimmer forums, but I can never get a response. I believe you guys can help me out.******
I've search hundreds of threads and can't seem to find a clear answer.
Car just randomly started to idle rough as I pulled into my driveway. Has horrible acceleration/ coughing.
ONLY GET ONE CODE - Cylinder 2 misfire. Sometimes random cylinder misfire as well if left on long enough.
This only happens when the car warms up. After about 60 sec I hear the actuators on the top of the valve covers click a few times and then the car shuts off cylinder 2. At this point the CEL usually comes up and the car begins to shake.
Note- If I pull the maf the car runs smooth. Just a bit laggy on throttle response.
I swapped coils and still get misfire on cylinder 2.
Probably not related, but Cylinder 1 coil had a bit of oil on it, probably time to get new gaskets.
I can also feel the left actuator ticking much harder than the one on the drivers side.
What do you guys think this could be??? I need this fixed asap its my DD.
- - - Updated - - -
Also after swapping the plugs I noticed they had oil on them. Not on the spark area , but on the thread and higher. Is this normal? Would this cause a misfire?
This was in cylinders 1 and 2.
The injectors also had lots of gunk oil build up on them.
Haven't swapped them yet, gotta fix a mini coolant leak first.
Also to note the pcv ccvs are leaking oil into the intake. Idk, if this is normal for a little bit of oil to be in there, but maybe this has correlation to the underlying problem.
Read post #15
2007 750i 84k
- - - Updated - - -
