So it's been a while since I've posted anything, mostly because I haven't smoked a new V8 mustang, gotten a 115 mph speeding ticket or even raced a kid on a 10 speed. But, I took the car in today for an oil change and wow did I spend a whole lot more than I thought!
Total repairs & upgrades = ~$2,500, plus stuff on the near horizon. I forget how expensive these cars can be... I knew some of this was coming up soon but man, it sucks living in the city and not having a place to DIY anymore. That said, if you are in the SF/Bay area, I highly recommend my mechanic - Sokol at Euro Motor Cars. Did a lot of work for me at a very reasonable rate...
Maintenance Total - $1,200. Parts $480, Labor $720
1.) Oil change (5w-30) and filter -
2.) Replace control arm bushings
3.) Replace leaking oil gasket (stand gasket)
4.) Replace expansion tank and hoses (thermostat done earlier, water pump looks ok)
5.) Replace all cooling hoses
6.) Replace the awful Bosch 4 plugs that are causing a cylinder 1 misfire
"Upgrades" as rear suspension is gone
1.) KONI FSD's from tire rack - $800
2.) Installation & alignment - ~$450
Repairs that will need to be done soon...
1.) Rear differential shows signs of leaking - need to replace gaskets and flush
2.) Power steering pumps starting to show leakage
3.) Rear tires worn heavily on insides, need to replace soon
4.) Front rims slightly bent, but still balancing OK with extra weights...
Guess I should also replace the tranny fluid while I'm at it.
I love my car, i love my car, i love my car....ugh
