1 - 2 of 2 Posts
I have some 8.5j et13 rims all around, can I put 265/35/r18 on rear without any problems like tire rubbing on fenders? I have a 2000 e39 520d.
Certifiable BMW Whackjob!
So lets ignore 265's shouldn't be put on 8.5" wide rims for the moment...they will fit in the wheel well with the correct offset.
It sounds like you already have those rims on the car? If so just measure your clearance. Using the same rim if you mount a tire 20mm wider it will be 10mm closer to the shock and 10mm closer to the fender.
sent from the future using the bimmerfest app embedded in my neural implant
1 - 2 of 2 Posts
