Bentley has a good section on the function of the check engine light (CEL); how it turns on, when it turns off, and how long it stays in memory. To badly summarize about 5 pages of text, the CEL comes on for a miriad of causes. If it is a serious cause, it comes on immediately. If it is a less serious cause, it can take a few drive cycles to confirm the problem. If the problem goes away, then the light will stay on a few cycles until the problem is confirmed to have gone away. The error then stays in memory for 40 to 80 drive cycles before getting erased. (Think of a drive cycle as a startup from cold, get up to operating temperature, and then have the Engine Management system complete its diagnostic test.)
What this means is that the problem went away a few drive cycles before you switched gasoline. It was likely just a coincidence that the light went out at that time.
I would not replace the O2 sensors... yet. You should have the code read, or invest in an OBD II or Peake Reader and do it yourself. It would be a shame to spend a few hundred $ on sensors when they may not be required. Believe me, there are
many causes of a CEL.
SoCaLE39 said:
ive filled my tank more than 10 times the same way and have had the same problem until i filled it with 89 octane so im pretty sure the cap was on correctly. Its a mystery!!! I think im just going to have to put some new o2 sensors in just to be sure!
