Is accurate...the thing to note is diesel does not ignite with spark it ignites with compression. Which is why manufacturers with HIGH COMPRESSION engines recommend higher octane ratings. Because as you cite higher numbers are the resistance to predetonation or ignition by compression and flash point which is affected by temperature and altitude.JP5 is refined to be diesel fuel, not gasoline. Diesel fuel is rated by Cetane number, relaed to self-ignition properties.
Octane rating is a measure of resistance to self-ignition.
My gas cap recommends a minimum of 89 pump octane (R+M/2). So, if your car runs okay with 89, use it. In CA, the difference per gallon between 89 and 91 is $0.20. With gas at $3.70+, that's not much.
TEAM V-POWER :thumbup:![]()
Must have used lots of q-tipsTo answer your question, 87 is minimum to use in all 99 and newer tu engine cars, 91 is recommended. It's on the sticker on your fuel cap.
1. Is it ok to use 89 Octane gas (Chevron with Techron) in my 99 V8 540i?
2. Any comments, recommendations?
:dunno:
That's EZ when the car doesn't leave the garage. :thumbup:
