All I have a car as stated in the subject that won't pass emissions. Here are the test results:
HC GPM Reading: 2.8121 limit is 1.500 (fail) CO GPM Reading: 57.8164 limit is 15.000 (fail)
CO2 GPM Reading: 347.2868
NOx GPM Reading: 0.0567
Catalytic converter--Pass
Fuel Filter Restrictor--N/A
Air Injection System: N/A
Oxygen Sensor: Pass
Check Engine Light--Fail
High HC reading:
High HC Readings are a result of unburned or partially burned fuel
High CO readings occur when the air/fuel mixture is too rich
With that said ... it seems to me that the thing is getting too much fuel. When I changed the plugs, all of them appeared to have been running rich. There as also a slight burble in the idle once the car was warm. So I replaced all of the Vacume lines and changed the fuel pressure regulator as the car has 165K miles. Took it in and had it re-tested and the HC and CO readings actually got worse and read what you see posted above.
Now I'm just a shade tree mechanic but I have owned several older BMWs int he past and here are my general assumptions:
1. If it were an injector ... only one cylinder would have apeared to be rich when I swapped out the plugs. All 6 had dark, shiney black deposits as if all 6 cylinders were running too rich.
2. The fuel pressure and vacume hose replacement cleared the erattic idle but made the emissions worse.
3. Since this is the M50 motor the coil packs are on each cylinder and there must be some sensor bad that is causing the ECU to deliver too much gas. Guess I'm trying to say ... it ain't the distributor cause there isn't one.
4. If it was the TPS the idle would hunt ... the idle is steady so TPS is probably set right.
5. If it was the O2 or cat, the numbers might be slightly over by not by the percentages shown in the test.
Can anyone give me an idea of what to test first and maybe provide a diagnostic decision tree based on experience? I have a bently and when I get back to Denver this weekend I'll start going through that if no one has a better idea. Guess I was just wondering if there was a thermo time swicth or something like the older BMWs had that might be an immediate suspect?
Oxygen Sensor: Pass
High HC reading:
