I'll list a few things. Do what you can, seek out resourses for the things that you feel are beyond you. Change the fuel filter. Flush the fuel lines. Check the fuel pressure in the injector rail. Clean the electrical connections (with switch cleaner) to the fuel pump relay, fuel pump fuse and fuel pump. Check and claen the earths to the relay, pump, battery and ecu. I guess that one (or a combination) of those processes will fix your problem. Fuel pressure should be a minium of 40psi. Low pressure could be the regulator or pump.
