1 - 4 of 4 Posts
Is the only thing that seals the thermostat cover (up to 9/98 build date) are the two O-rings (one on the thermostat and the other odd shaped one). I did not have gasket that follows the outside curvature of the housing. A new housing does not have outside gasket build in does it?
Thanks,
Mike
same design
Replacement housings (aluminum) use the same design, and you need to buy that odd shaped gasket seperately. (at least i did)
-Jim
Discussion Starter · #4 ·
I did not really get an answer but from looking at parts fische and manuals I figured it was this way. I did not have any other gaskets than those mentioned above. I installed the BMW OEM cover and thermostat and have no leaks.
Thanks,
Mike
1 - 4 of 4 Posts
