1 - 3 of 3 Posts
ive got a 98 740 with 140k miles, the problem is when you go over the slightest bump or go down a rough road there is a rattle sounds like a loose strut or worn front end component. ive replaced the tie rods/center link, the control arms as well as the thrust arms with no luck on the rattle going away...as far as the struts are concerned Ive done the generic push the front end down and see how many times it bounces and the result is when i stop pushing the front end down it stops bouncing (i don't here the rattle when pushing it), is it possible that the mounts are bad and the struts is good, and reason i cant duplicate the rattle is i just cant get the same movement by pushing on the front end as it would be from driving down the road? :dunno:
1 - 3 of 3 Posts
