1 - 4 of 4 Posts
My A/C is blowing warm... every once in a while it cools off for a few minutes, but still not as cool as it should be.
I tried recharging it but when I measured the pressure it was already at 65 (according to the can label that is too high, according to another DIY post that goes by temp & RH it still should only be at around 45)
Does this probably mean my compressor is bad? Could it be something else?
Thanks!!
Any compressor knocking noise when you press gas pedel?
Is your car shaking when the AC is on?
Does your AC blow warm air at low speed, and cold air when you drive fast?
Discussion Starter #3
No knocking noises that I have noticed...
Car doesn't Shake
Speed doesn't seem to matter, it will randomly (not often) get slightly cooler for short periods
It is possible to have too much pressure if charged when the temp was lower. I would have a pro look at it and potentially let some out.
1 - 4 of 4 Posts
