Alright I've read every thread on this topic google can find to the point every single link is purple because I've already clicked on it.
My problem is simply that my a/c compressor will not engage.
Here's what I've done to no avail:
Checked fuses in glove compartment and above battery.
Changed FSU (fixed fan speed).
Applied direct power to compressor and it engages fine and blows ice cold. Also checked pressure with compressor engaged and it is normal.
Everything works on the control panel and all buttons light up but it the compressor simply won't engage.
AUX fan takes a few minutes to engage but once it does it functions normally. Is that normal?
I checked the voltage of the plug that connects to the compressor and found it reads about 8 volts. Does not change when snowflake button is pressed or not (green light on or off).
Please help. I'm at a dead end and I can't take the 100+ degree weather with serious humidity in my black car...
