Hi Guys, i'm new to posting. so be gentle.
i have a 06 530I blowing warm air and it just hit 100+ degrees in the car today in Florida. i grew up in Ireland so if i don't fix it soon im going to rent it out as a mobile sauna.
I have a bit of a time crunch thats why i'm bringing in the big guns.
I have previously read all the A/C threads I could find, and 2 trees from the amazon to print them out. But I need an A/C Wizard to help with Diagnostic.
I'm not sure how to check the sensors and the compressor or in what order.
Here is some Specifics
Trouble code: 9c54 IHKA: AUC Sensor
(I will post more codes later but i have to switch to windows to read them from scanner)
System has pressure, high low & high side pressure
the aux fan behind the radiator does not run when the AC is on
Max AC comes on and blows warm air randomly when it feels like it.
It does not get cold even at high speed.
When I press the snowflake button to turn on/off the AC unit, engine RPMs change
All inside settings set for cold
high amp fuse to the compressor & the low amp fuse from the dash are good.
i have Bentley Manual, and probably every document posted on the internet, I'm dizzy reading.
I have INPA, Rheingold and the Schwaben Professional Scan Tool For BMWs.
I have A/C gauges, A big drum of Freon, and all the tools required to turn it into a tank, a-team style.
I even have a 2008 528i to interchange parts if they are compatible.
But what i don't have is a solid answer to what components to start with or the proper procedure to check the a/c compressor.
I've read the HVAC Control Module sends a signal to the AC Clutch when told to do so & the pressure switch is connected in series, this means too low or too high pressure of R134a will not allow the compressor to engage. But i'm not sure how to check the sensors,
I did the rocker cover gasket, but i think it was leaking oil onto the compressor.
it was sitting a while and had a bunch of leaves in and around the filters at the bulk head under the hood.
it also had the water pump replaced, before I got it.
I reconditioned the Valvebody, mechatronics etc so its been up and down like a $5 hookers knickers on New Years Eve.
I would be eternally grateful if someone could help me get a little cold air blowing on this pasty white Irishmans head in the not too distant future, I seen a pitbull licking his lips outside publix today and i'm fairly sure he was thinking just another 5 mins and this ****er will be cooked just how i like em. Thanks in advance.
