Hey Guys, my first time to ask for help! I usually finds similar problems here and find a solution for it but not this one!
My problem started last month when I changed the headlights and removed the negative of the battery. That day after I connected the battery back and I connected my computer to check the ECU and make sure everything it's ok, I found out that I have problem with Map Cooling (P1622) and once I cleared it and removed the cable, there was a huge white steam or a smoke came out from the Exhaust side and it has funny smell like some kind of gas and instantly the A/C lost the cold air! Every time that happened I have to fill some Freon to make it as cold as before and I also noticed that the auxiliary fan doesn't work all the time as before!!!
I checked the fuses for the auxiliary fan and it's all good, I connected the fan to straight DC and it worked fine!
I have no over heating problem and temperature gauge points in the middle as it supposed to be knowing also that I live in Memphis TN and it's 100F degrees all day! Also, am not loosing power or anything like that!
Could it be the thermostat (P1622) that make the auxiliary fan disfunction and cause that leak of gas?! or is it something else?
BTW, I have an 528i 2000 ( My poor Lilly :-( )
:dunno::dunno::dunno:
