The screwdriver handle is used to remove the DEF caps when refilling, so it is good that you have that. Sounds to me like you have everything, I cant recall anything more other than maybe the plastic adapter for the larger diesel nozzles. This comes in very handy when you are running low on fuel and you finally find a diesel station which only has the larger nozzles for trucks.
