1 - 9 of 9 Posts
okies - few fundamentals and attempted fixes/explorations thus far
bought 1992 535i bout a year ago- no complaints - lotta likes about the overall engineering
few repairs to be expected on 250000 miles- but relatively easy - few beers and go
power windows were best words - off and on erratic - soo start with drivers front - pulled panel and tore down motor- jeezzzz - the armature was scored similar to that of brake rotor long overdue for replacement - my guess 3/32" - seriously - but 250000 miles - okies - but not convinced mileage would score an armature that much- replaced - works one way - reverse the wires (2 of em at motor) works the other way - replaced master switch w/new one - piece of cake - worked a few times both ways but them jammo jammo - okies getting serious time here- removed door- checked ALL wires for cracks, breaks etc etc - all good - dig, check dig check - FRONT window guide is kinked - dam impossible to do w/o door being busted b4 - maybe but not the case 100% sure - replaced - reinstalled door - better but still one way operation unless reverse manually the 2 wires- 1 out of 10 tries it goes both ways - got all voltages good at motor , switch, fuses (front & rear) - grounds are good - other 3 windows - erratic at best
haven't checked the fusible link yet - but not symptoms of one bad anywhere else
am thinking faulty relay because of erratic operation- Bentleys manual is clear that there is one but can't find it- front or rear - haven't looked under glove box yet- but so far that seems fuses- and have researched this forum - quite an excellent forum - to no avail yet - another possible culprit is general module- took covers off- all looks good - solder joints, components etc
any solutions? and keep in mind one way operation (not pulling panel yet anytime operation is a convenience) and relay location:dunno::mad::dunno::)
Discussion Starter #4 (Edited)
switch
yep bought new master window switch (no individual switches for doors- just the master) - works good - but I get 12V to only one wire at the motor in the door) this is why I can only go in one direction - unless I pull door panel and physically swap the wires - have traced physically from door to master switch in console - am thinking a separate new wire from switch - under dash - through door to motor as-I can get 12 v from either side of switch to the one wire at motor
Discussion Starter #5 (Edited)
Discussion Starter #6 (Edited)
switch
Yeah, I like the switch.
Discussion Starter #7
I wonder if one of the wires to the motor has broken at the door hinge. The wiring there flexes a lot with the opening and closing of the door and can fail due to metal fatigue. You could check it for continuity ...
Discussion Starter #9
switch
thks 4 ur reply but is more complicated-pls review my original post- and btw relay module visually is in excellent shape -and I am not into being a parts changer- accurate diagnosis first then change as needed:thumbup:
1 - 9 of 9 Posts
