ABL-PRF-CHECK_ECU_PROGRAMMING = ACTIONFAILED
715 views 4 replies 3 participants last post by  Nickmonc
#1 · (Edited)
Hi all
I am getting the above error trying to program with ISTA+. Could it be because my ECU is flashed with MHD? Car is 2012 F20 M135i. Current I-level F020-15-07-506. Using ISTA+ 4.32.15.
- Thanks, Niels
@Siki78 You seems to know your way around ISTA :) Any ideas?
#2 ·
Hi all
- Thanks, Niels
I meme there have been cases where the tune on the dme can cause issues. Best way is to try to revert it to stock and try again. As is, when you program it, the tune will be gone anyway
#4 · (Edited)
Like @Nickmonc said flash with esys dme first
Flashed DME back to stock with MHD. Essentially removing MHD from the car. Now this problem... MHD has always proclaimed flash counter disabled, looks like not the case.
Even I select Advanced I am forced to program the DME..?
This post has been deleted
