get a third party pre purchase inspection if you're very interested...
This is the best advice! Make sure you get a mechanic that will be able to read BMW specific Error Memory Codes. As with any used car, I would also do a compression check on the cylinders.
At 130k miles, you're a bit at the mercy of how diligent the previous owners were with preventative maintenance & timely repairs. Your post purchase financial investment into the car could be relatively minimal or it could be significant.
Car is in great shape. $8500. How does that number sound to all y’all?
18 months ago I was looking at used 535s w/ 100k+ miles and they were all going for $12k+
Anything other than the fuel pump that I have to watch out for with this yr/model?
As with any used car, I'd plan on changing all the fluids & filters (engine oil, transmission oil, differential, transfer case, brake, coolant, power steering). Some of those aren't as "necessary" as others, but I like to have a solid known point for future service schedule (especially when previous services are unknown).
Check for Oil Filter Housing Gasket leaks (OFHG) as this oil leak should be fixed quickly.
Check to see if the transmission as ever been serviced (filter/pan & fluid change) as this is one of those items where BMW identifies as "lifetime fluid"; however, the manufacturer recommends servicing in the 50k-60k mile range.
Check for battery age/condition.
Check the driveshaft flex disc (Guibo) - this is the weakest link and is know to crack.
If/When you replace the water pump, consider replacing the coolant flange (i.e. the mickey mouse flange) with an aluminum aftermarket (they're cheap). Heck, all the hoses and thermostat too.
If/When you replace the serpentine belt, tensioner, & pulley, consider adding an aftermarket Crank Seal Guard w/ Crank Bolt Capture.
Hey y’all. I’m just about to finalize a deal for a 2011 535ix for my sons 18th birthday
That's a pretty awesome gift! Happy Birthday to your son & congratulations to you Dad!!!
