I just had both of my rear wheel bearings replaced at a local shop, not a BMW dealer. Now the ABS, BRAKE, and one more warning light are on. I can't use cruise control. I believe that a sensor was damaged or not hooked back up properly? Does anyone have any ideas for an easy fix for this? Is there any way to bypass/turn off this warning so I can use cruise control? Thank you for any suggestions.
