Already did a search and I'm having a very original issue.
My 2007 328i manual trans prod date 2/07, at first had an intermittent issue where the cruise, hill stop, traction, and abs all shut down while at the same time warnings for all pop up. Now this issue is permanent or so I thought. After about a month of having these lights pop up, they went away for 70 miles, and did not turn on until I decelerated with my cruise control. It felt different than ever. Instead of braking and precisely going to the set speed, it slowed down way below the determined speed, then kicked the cruise on and sped back up to said speed. Then within seconds, the trifecta came back.
I called two places including module master, and they both said with codes 5df0 and 5df1 I only need to calibrate my slz steering angle sensor. I have checked all wheel sensors, and everything else works. Wipers, signals, headlights etc, but like I said before, no cruise, abs, dsc.
I have edibias and toolset32 which I used to read codes and do the calibration, but unfortunately this did not fix it.
Does anybody have any suggestions on what I could try?
