Yes a new IHKA panel must be coded to the car.
Hey guys. I'll walk you guys through the problem series.
1. My IHKA went out (no display at all), and the car started blowing hot air out of the foot well vents constantly, even when off.
2. Replaced the FSU to no avail. This didn't change anything.
3. Replaced the IHKA, the screen on the new IHKA is working and the car isn't blowing hot air anymore.
I still dont have AC though, the AC doesn't respond at all. No hot or cold air, just no air at all. What should I troubleshoot next? What could the problem be?
Doug Huffman advised "The Hot-water Control Valve is normally OPEN and energized by the "A/C control unit" to SHUT." in a previous post, so that explains that.
Home gamer can do it. If the home gamer has module coding software.
ISTA
Man, mine is an '01 540i Wagon. I don't know how likely it will be for me to come across another one. Do you know what options/attributes must be the same for it to work? Even so, I might just have it coded to work anyway.If you get the IHKA from the same year and model coding is not required.
My 1999 528iT was not working correctly in Auto so I replaced it with another from another 1999 528iT and have no issues.
5' E39 | 520d | Touring | ECE |
5' E39 | 520i | Saloon | EGY |
5' E39 | 520i | Saloon | IDN |
5' E39 | 520i | Saloon | MYS |
5' E39 | 520i M52 | Saloon | ECE |
5' E39 | 520i M52 | Touring | ECE |
5' E39 | 520i M54 | Saloon | ECE |
5' E39 | 520i M54 | Touring | ECE |
5' E39 | 523i | Saloon | ECE |
5' E39 | 523i | Saloon | MYS |
5' E39 | 523i | Saloon | PHL |
5' E39 | 523i | Saloon | RUS |
5' E39 | 523i | Saloon | THA |
5' E39 | 523i | Saloon | ZA |
5' E39 | 523i | Touring | ECE |
5' E39 | 523i 2.4 | Saloon | THA |
5' E39 | 525d | Saloon | ECE |
5' E39 | 525d | Touring | ECE |
5' E39 | 525i | Saloon | ECE |
5' E39 | 525i | Saloon | EGY |
5' E39 | 525i | Saloon | IDN |
5' E39 | 525i | Saloon | MYS |
5' E39 | 525i | Saloon | RUS |
5' E39 | 525i | Saloon | USA |
5' E39 | 525i | Saloon | VNM |
5' E39 | 525i | Touring | ECE |
5' E39 | 525i | Touring | USA |
5' E39 | 525td | Saloon | ECE |
5' E39 | 525tds | Saloon | ECE |
5' E39 | 525tds | Touring | ECE |
5' E39 | 528i | Saloon | ECE |
5' E39 | 528i | Saloon | IDN |
5' E39 | 528i | Saloon | MEX |
5' E39 | 528i | Saloon | MYS |
5' E39 | 528i | Saloon | RUS |
5' E39 | 528i | Saloon | USA |
5' E39 | 528i | Saloon | VNM |
5' E39 | 528i | Saloon | ZA |
5' E39 | 528i | Touring | ECE |
5' E39 | 528i | Touring | USA |
5' E39 | 530d | Saloon | ECE |
5' E39 | 530d | Touring | ECE |
5' E39 | 530i | Saloon | ECE |
5' E39 | 530i | Saloon | IDN |
5' E39 | 530i | Saloon | MYS |
5' E39 | 530i | Saloon | RUS |
5' E39 | 530i | Saloon | THA |
5' E39 | 530i | Saloon | USA |
5' E39 | 530i | Touring | ECE |
5' E39 | 535i | Saloon | ECE |
5' E39 | 540i | Saloon | ECE |
5' E39 | 540i | Saloon | USA |
5' E39 | 540i | Saloon | ZA |
5' E39 | 540i | Touring | ECE |
5' E39 | 540i | Touring | USA |
5' E39 | M5 | Saloon | ECE |
5' E39 | M5 | Saloon | USA |
5' E39 | M5 | Saloon | ZA |
The ETK just shows one from 09/00 on.
5' E39 520d Touring ECE 5' E39 520i Saloon EGY 5' E39 520i Saloon IDN 5' E39 520i Saloon MYS 5' E39 520i M52 Saloon ECE 5' E39 520i M52 Touring ECE 5' E39 520i M54 Saloon ECE 5' E39 520i M54 Touring ECE 5' E39 523i Saloon ECE 5' E39 523i Saloon MYS 5' E39 523i Saloon PHL 5' E39 523i Saloon RUS 5' E39 523i Saloon THA 5' E39 523i Saloon ZA 5' E39 523i Touring ECE 5' E39 523i 2.4 Saloon THA 5' E39 525d Saloon ECE 5' E39 525d Touring ECE 5' E39 525i Saloon ECE 5' E39 525i Saloon EGY 5' E39 525i Saloon IDN 5' E39 525i Saloon MYS 5' E39 525i Saloon RUS 5' E39 525i Saloon USA 5' E39 525i Saloon VNM 5' E39 525i Touring ECE 5' E39 525i Touring USA 5' E39 525td Saloon ECE 5' E39 525tds Saloon ECE 5' E39 525tds Touring ECE 5' E39 528i Saloon ECE 5' E39 528i Saloon IDN 5' E39 528i Saloon MEX 5' E39 528i Saloon MYS 5' E39 528i Saloon RUS 5' E39 528i Saloon USA 5' E39 528i Saloon VNM 5' E39 528i Saloon ZA 5' E39 528i Touring ECE 5' E39 528i Touring USA 5' E39 530d Saloon ECE 5' E39 530d Touring ECE 5' E39 530i Saloon ECE 5' E39 530i Saloon IDN 5' E39 530i Saloon MYS 5' E39 530i Saloon RUS 5' E39 530i Saloon THA 5' E39 530i Saloon USA 5' E39 530i Touring ECE 5' E39 535i Saloon ECE 5' E39 540i Saloon ECE 5' E39 540i Saloon USA 5' E39 540i Saloon ZA 5' E39 540i Touring ECE 5' E39 540i Touring USA 5' E39 M5 Saloon ECE 5' E39 M5 Saloon USA 5' E39 M5 Saloon ZA
