I doubt this would happen since the accelerator is Drive by wire. The only way this could happen was if the sensor went way off and failed. If this were to happen, Switch to M mode and start upshifting ASAP and get on the brakes, you won't have much HP/TQ in higher gears at lower speeds and the brakes should be able to overcome it. Also switching to N may work, but it may not work since the gearshift is electrical and not mechanical.
