1 - 20 of 20 Posts
Premium Member
Is there any other software available to code the F Series as it looks like E-sys is not a viable option.
Why is E-Sys not viable option? :dunno:
I have tried to get a token for E-sys and failed miserably. I have used E-sys to change my VO but want to edit the CAFD files.
In the past I have always done my coding by laptop but after the last few days I was actually considering an app based system like BimmerCode or Carly.
Premium Member
You just need to use E-Sys Launcher PREMIUM 2.8.2 and Rearm Script.
That sounds promising I have tried several versions of the launcher and just spotted the 2.8.x will try it on my laptop in the morning
Thanks Shawn.:rofl:
Shawn, you seem to be the resident guru for E-sys, I have spent hours trying to install E-sys on 2 laptops and both have failed to run the rearm and I have been trying for 6 hours.
I am trying to set up with:
E-sys 3.27.1
E-sys Launcher 2.8.2
Rearm 2.0.0
The errors are:
Laptop 1 - there was a problem redating C:\Users\STEVEQ-1\Appdata\Local\Temp\*
Laptop 2 - there was a problem redating C:\ProgramData
Any advice would be greatly appreciated.
Premium Member
E-sys 3.27.1
Rearm 2.0.0
The errors are:
Sorry, but I cannot help with the Rearm Script. I never use it myself as I have working PRO version. You need to contact the Rearm Script Developer Tony and ask him.
E-sys 3.27.1
Rearm 2.0.0
The errors are:
Maybe just obvious points but you need to set your pc system date within the range prescribed (so for Launcher 2.8.2 - a date on 2018 not 2019). Trying to re-arm outside axcceptable date range for launcher will fail. Also you need to launch/run apps in admin mode (right click run administrator), finally I had problems initially because my laptop had insufficient free ram, 4gb total and less than 1gb free. I doubt it is worth trying to run any of these apps unless you have 6-8gb ram (and therefore 4-6+gb free ram) on the device. Re-arm needs to reset date for all the temp files otherwise launcher will detect and not run, if re-arm cannot access or change dates, make sure the folders are not read only and/or they your fireWall is not blocking re-arm.
Windows10(1809)
Windows10(1809) can NOT work! I don’t know other Windows10 work.
Windows 7 CAN work!
Is there any way to use E-sys again ? as i can ready tokenmaster ist not reachable and do not reply. is there another way to use E-sys?
Premium Member
Everytime i want to code something i Need 5 days to reinstall everything, or recrack everything. so bad that TM is not answering anymore.
E-Sys launcher doesnt start anymore so i cant test rearm script.
I realy want pay Money for the solution that it works. but if there is noone out there anymore ... its just frustrating
Premium Member
Get ESysX instead:
[email protected]
http://esysx.com/
Try this option from TM himself. Re-arm not necessary and indefinite licence for an older Pro version.
https://tokenmaster.blogspot.com/2019/05/e-sys-launcher-pro-282.html
Premium Member
Premium Member
1 - 20 of 20 Posts
