1 - 2 of 2 Posts
The rear driver side door is locked and does not open until I remove the door panel and release it manually. After that, I could open and close the door until I lock the car using the remote key THEN I would not be able to open the door until I remove the panel again....
Is there anything needed to be adjusted on the actuator?? The door open and close regularly, only when I lock it with the remote key I would not be able to open it until i remove the door panel.
P.S: I noticed two of the pins of the electric plug connection of the actuator are missing or broken off. I do not know whether they suppose to be that way or insurance company broke it off when salvaging the car....
Thank you
Test for voltage to the actuator when unlocking...if it shows 12v get a new actuator
Sent from my LG-H901 using Tapatalk
1 - 2 of 2 Posts
