aFe products are great and we actually run them on our own shop cars. The most popular choice is the aFe stage 2 intake.
The
aFe Stage 2 Intake replaces your restrictive factory air box which allows for an increased air flow meaning more horsepower
(27 hp / 34 ft/lb torque peak gains). Another feature of the intake is the 16 gauge powder coated steel heat shield. A heat shield makes sure that the intake doesn't use the hot air around your engine and only allows the intake to receive cooler air, which adds more power. Not only does power increase, but many have observed an increase in MPG.
If you're looking for a completely sealed system, you can check out the
aFe stage 2 sealed intake. The aFe sealed system produces
14 max hp and 27 lbs. x ft. torque. This radically different Stage 2 sealed cold air intake system is engineered to let maximum air in while keeping engine heat out. It smoothly directs increased air flow for improved volumetric efficiency and maximum performance. So effective is the design that Intake Air Temperature (IAT) at normal running speeds with this aFe intake system is 11 degrees lower than the factory intake.
