Z3 1.9l air filter box has what appears to be insulating material attached to the inside walls by means of a plastic mesh. This material is disintegrating and I fear that particles from above the element could be sucked into the motor. Should I just remove the remainder, or is it necessary to replace it, and if so, with what? Thank you.
