it wouldnt fan wise. fyi, the FSU is not a resistor, its a solid state component, PWM controlled by the IKHA. do the fan speed led indicators travel from low to full speed? id read the IKHA module for errors, and see what it says.
Thanks for response.it wouldnt fan wise. fyi, the FSU is not a resistor, its a solid state component, PWM controlled by the IKHA. do the fan speed led indicators travel from low to full speed? id read the IKHA module for errors, and see what it says.
Yes, I am able to change the fan speed from low to high and so on. But nothing happens since there's no air blowing from the vents. So yi
I hear nothing from the air vents. I do hear the defroster fans and they work fine. Check this image for reference. The air vents that I have drawn a red circle around don't work, but where there is a green line it is working fine.do you hear the fan running just no air from the vents or is there no fan sound? read the IKHA for errors. itll take a BMW specific scanner to do so.
Hey man!When this happened on my car it was the Final Stage Resistor. Replaced it and the whole AC system worked better.
