1 - 1 of 1 Posts
Swapped seats in e70, and those swapped seats didin't had a belt tensioners (no wires) as previous ones did. So now airbag light is lit. Decided to code tensioners out, but strange thing happened. After I have coded it out with ncsexpert. Did sg_codieren, everything went ok. I got "coding done" message. But guess what? Airbag light still on, hmm ok. I read the trc file again (with ncsdummy). And guess what? Tensioners are set to activ. Mm ok? Changed to nicht_active, coded again. And same thing happened.
Whats wrong? Is the airbag module locked or I need to do something more?
Sent from my LEX722 using Bimmerfest mobile app
1 - 1 of 1 Posts
