1 - 3 of 3 Posts
Out of nowhere my 05 Z4 dashboard airbag warning light came on. I used my OBD ll reader and it shows no active error codes. What should I look for? Could it be a blown fuse? Loose wire?
Any suggestions would be helpful.
A standard OBD II reader will not pull error codes from the airbag module. You need a BMW specific diagnostic tool to read the error code(s).
Discussion Starter · #3 ·
Is it possible that the fuse for the airbags blew? Is it easy to check? My manual says the fuse box is in the glove box but doesn’t go into any detail on how to find and examine it.
1 - 3 of 3 Posts
