1 - 3 of 3 Posts
Car: 1985 325e
Suddenly the alarm (which I have never used and I take to be factory equipment) blares continually. I have to disconnect the battery to silence it. I cannot locate (or have not to date) the noise maker.
I would like to disable this system if possible. Can I simply disconnect the noise maker, assuming I can find it? Any suggestions or information would be appreciated. My manuals have not been any help.
Also, in the process of bumbling with the OBC, in the dark, I seem to have set the security code to some unknown number (I've always avoided this feature as well). Is there some way to reset this?
This has not been a good week.
Disconnect the battery for a period of longer than 30 minutes. The security code will clear out of the obc. The horn is located normally on the drivers side on the shock tower.
Discussion Starter · #3 ·
Thanks. Does the alarm sound only in connection with the security code function? If so I asumme I can simply disconnect the horn since I don't use the security code.
1 - 3 of 3 Posts
