I own a 2011 328i coupe w/ standard sport suspension.
Does anyone know if the camber of the front wheels can be adjusted without using after-market parts? Is the camber non-adjustable?
Thanks all,
Jeff
Toe is entirely adjustable - research: tie rods.
Camber is mildly adjustable if you remove the pin. SEARCH the site and the net for the secret to your success!
Extensive Camber adj w/plates.
Castor not adjustable w/o plates w/that capability.
Camber is mildly adjustable if you remove the pin. SEARCH this site and the net for the secret to your success!
I searched the net and got different information depending on the model of the car.
Also searched this site and didn't see anything specific to my model.
Anyway, thanks for the information.
OK, start here .
If your concern is racing, you'll want plates after a number of other mods.
If you're experiencing odd tire wear, look to your bushings - stock are rubber.
Will be swapping out the stock dampers for the Koni FDS's. I understand that the car should be re-aligned, so I have 2 choices:
1. Dealership w/ fancy-schmancy alignment thingy with laser and printout.
2. Indy, specializing in alignments in my area for over 37 yrs. with great reputation. No printout, no laser (except for toe adjustment), uses bubble levels. Will put me or associate in driver's seat to compensate (I'm a pretty big guy!).
Prices are within $30 of each other so that's not an issue.
When I went to Indy shop to talk about alignment, he said my car does not have front wheel camber adjustment. I though i read that it did....so I did my searches.
In any event, I want a slightly "aggressive" stance since I'm a spirited driver and take part in a few HPDE's a year (no serious racing).
