1 - 20 of 25 Posts
E46 m50b30 from Romania.
Almost finish the turbo project on my e46 sedan, after 2 yrs of searching, buying parts, wrong and good decisions.
In few weeks the car will go to Bulgaria for new Ecu Master Emu Black instalation, soft and dyno... hope to get aprox 600hp.
Here are some pics with the engine, mounts, etc.
Soon, I will add here all parts involved in this project.
More pics to come... and the parts list, hoping this will help other ppl around.
After 2 days...
Continue work...
Unfortunately I got stuck in finishing because of the clutch... is too f..ing brutal... it seems is the wrong the distance between the flywheel and plate clutch. My mechanic will sort it out with a specialist but this makes to postpone the standalone instalation, wiring, settings, soft and dyno. Hope in 2 weeks I'll be done with this.
Meanwhile he'll restrength the chassis and noise insulation in entire vehicle.
Parts list:
1.Wastegate TIAL v60
2.Blowoff HKS
3.Gaz pomp Bosch 044 + reduction
4.Cometic head gesket
5.Siemens DEKA 830cc injectors
6.ARP studs
8.Turbo Blanket
9.Exhaust wrap roll-4 rolls
10.Single Pod Center Vent - OCPB-11
11.Auto Tech ATI-54MS-EPOD-52 ePod Gauge Pods
12.FITMENT SLEEVE ATI-52mm
13.HKS 41001-AK009 Black Type-0 Turbo Timer
14.HKS 4103-RM006 Turbo Timer Harness
15.BMW DUAL VANOS O-Ring Seal Repair Kit E36 E39 E46 E53 E60 E83 E85 M52tu M54 M56
16.NGK (4776) BKR7E-E V-Power Spark Plug
17.ECS Magnetic Oil Drain Plug
18.ECS Polyurethane Transmission Mount Set - Street/Track
19.ECS Carbon Fiber Strut Bar Kit – Black
20.Exact-Fit Stainless Steel Brake Lines – Kit
25.Forged pistons, rods and bearings
27.ECU MASTER EMU BLACK + bluetooth to check all parameters etc other than turbo boost/oil pressure/water temp gauges
33.3SDM 0.01 18" rims
35.BC Racing coilovers
37.M5 style mirrors
46.LSD diff 2,93
47.Turbine HOLSET HX35
48.M50 engine block & head cilinder, double vanos but evac vanos was cancelled
49.725 Twin Clutch from Clutch MAsters
51.e46 330d gearbox 5 speed-much betterthan 330i gearbox
52.ecs chassis reinforcement kit
55.Magnaflow mufflers-biggest possible for e46
56.Custom e46 m3 steering wheel
58.e36 steering rack
59.VDO Viewline boost, oil press, water temp gauges+sensors
67.STP Antirust Silver –noise insulation
68.VTT-MP-TT-001 – thermal insulation for engine bay, etc
ETC, ETC.. I hope soon I'll find a good big brake kit for it.
Sent from my iPhone using E46Fanatics mobile app
Discussion Starter #3
I m working in high risk areas for 8 month per year so imagine :)
Plus, my wife knows nothing about the project :))
Keeping it surreal
Be sure to post a few ACTION videos here after the project is completed ! :thumbup: :D
Discussion Starter #9 (Edited)
Uff, still on process... my mechanic supoose to go to Bulgaria to instal the new ECU MASTER EMU BLACK(awesome standalone) but the 725 twin clutch-Clutch Masters was too brutal. So I'm waiting now for the Hydraulic flow valve control from CM. This valve will maje the clutch softer.
Meanwhile just bought few goodies: new csf radiator and mishimoto expansion tank, revshift race flex disc, 62 degree mishimoto racing thermostat. Also added anti noise-vibrations STP antirust silver for entire car under the carpet. Waiting also for front Braum seats. Hope in 2 weeks will be ready for fuuuuuun
Discussion Starter #10
more stuff
New arrivals:
-CSF radiator
-Mishimoto expansion tank
-Clutch Maasters Hydraulic flow valve control-725 Twin clutch is too brutal for daily driving so this would make it softer
-BMW Performance BBK: 135i calipers, 330i stock bmw perf rotors, adapters(brackets) plus new EBC yellow stuff brake pads.
-Braum front seats from Vivid racing
Now the whole carpet is out to make place for noise & vibration cancelation STP Antirust Silver tape, starting from underneath the dashboard till the end of the car including the trunk.
As soon as the radiator, exp tank and the valve will arrive, the car will go for ECU EMU Black instalation on M50 electric instalation platform to Bulgaria... soft and dyno. I hope in 2, max 3 weeks to see my little project finally done.
Discussion Starter #12
I was happy to find a 725 clutch with less than 500 miles on it just for 900$ including shipping.
And also at that stage I thought that 725 would be enough for aprox 600hp , not knowing that there are other options too so I end up with it.
ANyway, according to Clutch Masters this hydraulic valve shoud do the job... we ll se...
beemlyfe
Was pondering the idea of turboing my e46 330i. Looks more complicated then I hoped.
Discussion Starter #14
First, I wanted to buy an m3 and to swap everything.
I couldn t find it at the price I wanted so I decided to go on turbo.
If I knew at that time few things about a turbo project I wouldn t so it honstly.
But the expectations are much higher than m3.
I realised in the end that a real turbo project cost if you want to do it right.
Keeping it surreal
Check if you have a supercharger kit for your vehicle
ANY forced-induction project will require a budget of (at least) $10,000 to do everything the proper way. There`s no "quick & easy" way to big horsepower with BMWs....
beemlyfe
You mean to say I can't just throw a cone air filter onto it and get 50 horsepower? Whaaatt?
But for real, I'm not sure what path to go down. I really want a high preformance e46, and my budget doesn't quite span to 10k.
Discussion Starter #18
What Fast Bob said is right and I think he is on the same frequence with me here: turbo doesn't mean just to through a turbine and few bits there, it means modifying the whole car... starting with the chassis, bushings, wheels, steering rack, even seats, engine-forged p&r, ECU, etc, etc. Why do you think a stock car with more than 400hp cost more than 100k?
So if you want a reliable turbo project cost. Mine is still ongoing... aprox 23k in the last year. Buuuut, it will be amaziiiing.
Looking forward to post it when finish it. In aprox 2 wks.
For now, few pics with STP Antirust Silver tape for noise & vibration cancelation.
So what you are saying is, you've spent $23k on your car and your wife has no idea you've done this? How is that possible unless you have money just oozing out from every where. Good luck with your build.
1 - 20 of 25 Posts
