Hey guys, so for the past month I have been having a problem with my 7. The car wouldnt start, it would give me parking error and ABS error and transmission error so I had to turn the car off and then jump start it.
After a while even after the jump start it wouldn't work, good thing I had a jump starter kit so I had it connected and drove with it connected to the battery for a few minutes then disconnected it to avoid getting the errors mentioned earlier.
Battery was tested good, so I thought it was the alternator but before replacing the wrong parts I went with the cheapest fix first which was replacing the battery. Cost me almost $35 for a rebuilt battery (no difference whatsoever from past experience) and my problems are gone.
Its been about 2 weeks and the 7 is running great, operating voltage is higher 13s or lower 14s. The only problem is that every once in a while I get an error saying GENERATOR FAULT in the mornings and the voltage drops to 11s.
I have done some research on the forum and I know that the problem is mainly the alternator, but what do you guys think? will I have the same problems again?
The battery is not registered either, where can I get that done and how much does it cost?
Thanks guys :thumbup:
