Hello I need some opinions possibly regarding the AMF sensor on 2001 e46 330xi.
The engine light lights up when the car is started in cold weather. It stays lit for a few days then it turns itself off. The idle is not really rough but could be smoother.
OBD Code states that the right and left banks are running too lean. No vacuum leaks have been found, the oxygen sensors are ok, and CCV is ok.
I cleaned the AMF sensor with the appropriate cleaner but it did not help.
For the sake of science I am willing to do an experiment: either do nothing and see what happens (anyone knows what terminal damage could come from that?), or replace the AMF sensor possibly with a factory refurbished for 190$ (local store parts). Also amazon has some cheap “new” AMF sensor for 65$. Has anyone tried that?
Thank you all
Thank you all
