Anybody else here ever have a broken front strut/shock coil spring?
This is the second time now for me
- less than 4 years after replacing the last set - typically it's best to replace suspension parts on both sides.
the first incident was on the original stock suspension when I noticed it when replacing the shocks 1st time (upgraded to Bilstein HD - love em)
so at the time I went ahead and replaced both springs in the front.
well less than 4 years later another broken spring - this time on the passenger side - first time it was driver/left side. the first time it broke off the bottom coil, and I did not even notice until replacement of shocks, this time it was worse the spring broke near the middle - I noticed suspension issues and noise, after backing out of garage and hearing a pop - in the end it created a big mess that made removing the strut and sway bar link a nightmare, after finally getting the strut out, I had to resort to an angle grinder to get the coil off - could not use spring compressor
. This coil spring was less than 4 years old - Suplex brand - I got these springs from an indy around me who said he got them from a dealer and charged accordingly. I think it is due to corrosion - salt attacks any nicks or areas in which the paint is not covering - or else it is due to this suspension - or Suplex sucks?
Now here is the important part of this - for xdrive most online parts stores - if they carry coil springs at all, many don't at least for the xdrive, only have OEM springs which are wicked pricey like $175 EACH - but they can be had for around $80 each. I had my local mechanic get a new set for me for $80 - I also found BavAuto has the Suplex brand for $83, the ones my mechanic got are another brand named Mubea.
