Apparently BMW classifies the "recall" and the "warranty" separately.
Engine light came one. OBDB pointed to fuel pump.
I took it to dealer and they said it could be fuel pump or sensor.
After diagnosing they said it was "both." HFPF was covered under warrantly. Low pressure sensor was not.
Now, the recall Technical Services bulletin said the LP sensor should be replaced under recall if it is bad. But the Warranty does not cover it. Since I already had the recall (this is third HPFP), they call it warranty work.
I cannot help but think that they either didn't test it according to the recall TSB methods and just "replaced" and that the problems related to the HPFP cause damage to the sensor (or why else would it need to be replaced under recall of the HPFP?).
I haven't seen this in the forum. Has anybody else run into the "This is warranty so it's not covered but it would have been covered if it was recall" problem? LP sense plus laber was about $250.
