I have 2000 528i. Cooling system was overhauled two months ago and bled properly. All of a sudden, temp needle shot up all the way to the right, but the red light did not illuminate. There was no smoke at all after driving the car for about five minutes and loss most of the coolant through the cap on the expansion tank. There was a total loss of power and lots of rattle/click type noises. Ses came on and Dis and Inpa both revealed oil temp sensor/coolant temp sensor faults/shorts negative ground. Now even when I depressed the clutch there are wierd sounds coming from the clutch area.
Is it possible for both sensors to go bad at the same time? Its sounds unlikely.
